Here is what I have done to my Radeon8500..
First I put a ThermalTake Blue Orb cooler on.. However this is the worst piece of junk cooler I have ever seen, warped and a waste of money..
I also got set of 2 ramsinks from ThermalTake as well, I cut these into individual pieces to fit ram.. used a dremel to cut them..
I then replaced my Blue Orb with a CPU cooler with a 6000rpm fan.. attached with Artic Alumina..
Hardware Volt-Modded the card after that.. you can see the resistors in the rear view picture..
Before All of this I had a Lemon of an Overclocker.. I could not overclock this card past 275.. Not even 1mhz more or it would Lock.. The ram prior would do 290mhz..
After the Ramsinks Ram would do 295..
After Volt mod V-core would do 297 Clean and 305 not so clean..
Ram 300 clean and upto 312 not so clean..
So my final overclock speeds, clean without any artifacts or tearing.. is 297/300...
What your card will achieve will depend on how well it does from the start, some people can get 305/305 or more without doing anyting to their card.. Wish I was that lucky.. =)
If a volt mod is needed, take your time and do it right.. and you will not have any problems..
See pics..
