Hello! First time poster, but been a lurker for a while. This will be my first time water cooling. I had a question about radiator choices for my build. I was thinking of going with a HW labs 360gts and 280gts, however, I'm not sure if these will provide enough cooling and I'm a little worried about how restrictive these radiators are. Theoretically they should provide around 500w cooling at 1000rpm with push only (which is the plan). I could go with a wider 360 in the front, but would have to change out the top rad for a 240 if so as the res/pump combo I'm planning on using will be a tight fit. Just looking for insight from people who know more and may have first hand experience. Any input is appreciated. Thanks!
Build:
Thermaltake view 31
Intel 8700k
Asus Rog Hero x Maximus
Asus rog vega 64
1000W PSU
I plan on using a vario d5 with a 250 bitspower mod top so it will be a pretty tall combo. I will be cooling the mobo/cpu with ek's m9h monoblock and the GPU with a full block as well. Here's a pic of how it currently sits.
Build:
Thermaltake view 31
Intel 8700k
Asus rog vega 64
1000W PSU
