L Luie Member Joined Sep 6, 2001 Location Irvine, CA Sep 19, 2001 #1 Are Ram Idle a worth the tweaks?
Placid Senior Member Joined Mar 13, 2001 Location Connecticut Sep 19, 2001 #2 If you have programs with memory leaks then yes. I have used MaxMem and found it work well. Simple installation and its free. http://www.analogx.com/contents/download/system/maxmem.htm
David Forums Super Moderator Joined Feb 20, 2001 Sep 22, 2001 #3 I like RAM Idle. It doesnt speed things up noticably, but its nice to see how much RAM is free.
Mr.Lansing Member Joined Jun 22, 2001 Sep 22, 2001 #4 Well actually i fink those programs are useless u can't feel the difference at all...
Sonny Senior TIFOSI Joined Aug 3, 2001 Location VARIANTE ASCARI Sep 22, 2001 #5 MaxMem works great. If you run 98SE use it. Try to visit the site & checkout the other utilities offered there. I'm sure you'll find something
OP L Luie Member Joined Sep 6, 2001 Location Irvine, CA Sep 23, 2001 Thread Starter #6 thanks, everyone. I got both programs (ram idle and maxmem) I am using ram idle now cause i think it is better. More tweaks! hehe
Krome Member Joined Jun 17, 2001 Location The Lone Star State Sep 23, 2001 #7 What about Cacheman 5? I have used it, and liked it, trying MaxMem now...
