- Apr 30, 2008
- Birmingham, UK
mgoode what settings are you using atm? I am about to start overclocking my setup and would like to know what voltages you are using for the CPU, NB and RAM (I have the same RAM I believe)
I'm jealous mgoode.
Cool. I am having trouble reaching 4.2Ghz Stable
Temps are fine, and memory runs no problem. What is the best configuration for 4.2Ghz with Bclock and multi, as in should the Bclock be towards 180 or lower with higher multi?
I am using 160x25 for 4.0Ghz 1.29Vcore for the moment. What other voltages did you set? There are a few others in my BIOS, of which I cannot remember the names. How did you manage such a high overclock on the RAM and manage to tighten the timings? I am so jealous
Thanks, I managed to get 4.2Ghz with 1.38Vcore. You wake up at 5am
This was around 160 bus speed, might see if 180 needs less volts but looking at yours it needs more. Also, not sure if memory will take it (don't need any more bandwitdh with triple channel anyway )
