T Tory Registered Joined Dec 19, 2003 Dec 21, 2003 #1 Hello,To all Can someone tell what type of Rams would i use with this board Abit NF7-S rev 2.0 Thank you
W wanna_b_rich_13 Member Joined Dec 15, 2003 Dec 21, 2003 #2 It uses PC2100, PC2700 and PC3200 memory.
OP T Tory Registered Joined Dec 19, 2003 Dec 21, 2003 Thread Starter #3 Hello,wanna_b_rich_13 Thank you well here is what i maybe using so far Abit NF7-S Rev2 AMD Athlon XP processor 2500+ so could you tell me what would be a good Ram to use Thank you
W wanna_b_rich_13 Member Joined Dec 15, 2003 Dec 21, 2003 #4 Do you plan to do any overclocking or are you just looking for the cheapest stuff to get your PC running? I can give you some examples of PC2100 that will cost next to nothing or some high quality PC3200 that will cost as much as the CPU and board togther.
OP T Tory Registered Joined Dec 19, 2003 Dec 21, 2003 Thread Starter #5 Hi,wanna_b_rich_13 Yes please could you give me some info on this one here high quality PC3200 Thank you
W wanna_b_rich_13 Member Joined Dec 15, 2003 Dec 22, 2003 #6 Here is a link: http://www.mushkin.com/epages/Mushk...000ccf0f4273fc0a80102063d/Product/View/991032
