- Mar 13, 2006
So I get back from traveling for work and sit down to check email and use internet that is above 9 kb/s for the first time in a month and notice a small issue...
It's VERY slow.
hmm, ok?
reboot AP, nope.
Notice DHCP isnt being provided.
Check IPCop and its still running but I smell a faint burnt smell.
OH CRAP!
Pull network down asap and remove the firewall from the rack. Pop the top and start looking for burn marks.
Cant find any.
Start stripping the system to see if it is the PSU or bottom of the board etc.
Get the system down to bare metal and dont see anything so I look at the HDD. Burn marks on the bottom... Uh oh.
Remove the screws holding the HDD in place and flip it over, wow! The 160gb WD drive decided that the controller card on the bottom of the drive was better served as charcoal.
Whatever happened it blew a couple chips completely off, removed some solder as well it appears.
Im not sure if it was the PSU or a random spike that ONLY affected the drive (I left my rack on which I dont like to do), either way my IPCOP install which had a large block list in place and automagically blocked port scanning IPs, pingers etc is lost.
Note to self, this time dump a copy of your configured Firewall after you get it built dufus!
Gotta say that the IPCOP dropped my throughput by about 500kb/s but I didnt have to worry about anyone getting in (tested it with a few folks doing port scans etc. It appeared to be a blackhole), now I get to look at a rebuild on HOPEFULLY a good system...
Firewall specs:
2x P3 800 @ 1.1ghz
2gb PC100 ECC @ stock
no HDD obviously
2u rackmount case
Im still working on pushing ad blocking back to the Firewall and off of the browser, the new job is preventing testing of this though.
Anyone using any IPCop addons that they would recommend?
It's VERY slow.
hmm, ok?
reboot AP, nope.
OH CRAP!
Cant find any.
Firewall specs:
2x P3 800 @ 1.1ghz
no HDD obviously
2u rackmount case
