habbajabba said:
No different than a pull-start UPS with a fuel gauge
Again, got a link to such a device? If you have to pull-start something to get it running, that clearly suggests it is not running until it is started. So how can it be called uninterruptible?
So again, you just don't seem to be thinking this through. If the device supplying backup power has to be started, there WILL be a gap in time between the loss of mains power and when your backup device kicks in. Even if that is just 1 second (1,000 milliseconds) - which would be remarkable - that is way too long and any computer would immediately come crashing down! Computer power supplies cannot and do not maintain output that long. The most they are required to maintain output is just 17 milliseconds. And not many are even able to do that.
storm-chaser said:
At this point I guess we have to assume American Airlines used a hybrid type backup system? Because Im with Bill, there is no way to fire a diesel generator in under a second... and that being said, the only theory that comes close to what you are describing would be a battery back up first as a buffer and then an automatic shift to diesel power once the generator gets up to speed.
Exactly! And that "buffer" is the "UPS". The diesel (or gasoline, or natural gas) engine that turns the generator is part of the backup power system -
NOT the uninterruptible power supply.
That "hybrid" type backup system is exactly what I was describing way back in
Post #28 with air traffic control tower communications systems. And Robert17, it is important to understand ATC communications systems are much more mission critical than any airline reservation system. Nobody is going to die, planes are not going crash if an airline reservation system goes down. But if a control tower suddenly loses comms, that affects both air and airport ground traffic safety.
So you are either confused about what you saw 35 years ago, or the techs who demonstrated it to you didn't explain it properly, or didn't know what they were talking about. Because you are right and there would be better solutions available today, but there aren't! For power to be truly
uninterruptible, the device providing that backup power
MUST already be up and running 24/7/365 - it would not have to be started first. Any delay imposed waiting for the backup device to start (whether automatic, or requiring a pull) would cause those mission critical systems to go down. That's just plain physics.
