S6 Active will not connect to my PC
BlueNostromo
My phone will not show up on my computer at all. It used to quite a while ago. MTP and USB debugging are both selected on my phone. All autoplay options are set to prompt me for action on my computer. My cables work perfectly fine and I have tried multiple. I have tried reinstalling the Samsung Drivers multiple times. No change. I am at a loss to why.
hokiealumnus
Water Cooled Moderator
Just to ensure it's nothing simple, when you plug it in, are you pulling down the notification panel on the phone and telling it to connect to the computer? On Marshmallow, the default action (on the phone) when plugged in is charge only. You have to tell it to connect to the computer for file transfers if that's what you're trying to do.
BlueNostromo
BlueNostromo
I do not know what you are talking about. There is no option to change anything.
- - - Updated - - -
Just use wifi file explorer pro. Then no cables are ever needed for any pc.
I have been looking for something like this. Thank you!
knoober
Seems like the wifi thingie might have you covered but just in case.... The path used to be Settings > PC Connetion (or connect to PC....specific name was different on different devices) > choose between charge only/Media transfer/camera mode
On my device with Android 6.0 (marshmallow) I have to go to Settings >Developer Options (sometimes this option is hidden unless you do a specific set of steps. Google for your device if it is not enabled by default. I have never seen a version of android without a way to enable Developer Options)...boy that was a long side comment .... Settings > Developer Options > Select USB Configuration > Charging/MTP/PTP/RNDIS/Audio Source/MIDI .They really beefed up the options. I dont know if those options are device specific or available to all Marshmallow users though. It is certain that you will have Charging/MTP/PTP or some variation of the three to choose from though. Choose MTP :D
hokiealumnus
After you plug the phone into the PC, there should be a non-dismissable notification. Pull down the notification panel and it will probably say something to the effect of 'Charging only'. Touch that and it will present you with options to connect as a media device for file transfer, connect as a camera, etc. Select for file transfer and the PC should then display the phone as a drive on your PC.
TechWizard
You probably need Kies.
http://www.samsung.com/in/support/usefulsoftware/KIES/
You don't need it to use the software suite - just for the driver portion it installs. After it installs you should be able to access your device like any flash drive or ext hard drive plugged into Windows.
I have the S5 Active and I needed the Kies drivers when flashing/modding my OS, before that I couldn't get a connection either.
