Well after careful reconsideration I've decided to go with the sempron 2800+ cause it was on sale for only $47 CAD and alot of people say you can easily overclock to 2.3ghz+ with stock cooling. Ne ways I won't be upgrading this comp with high end stuff so s754 is fine. All the stuff I got I made sure they are all good for Ocing, however I am not sure if they are 100% compatible or even that good, so if ne1 wants to check for me that would be great.
ANTEC SLK3000B ATX MID TOWER CASE Black 6X5.25 5X3.5 NO PS
LG GSA-H10N DVD+RW 16X8X16 DVD-RW 16X6X16 Dual Layer 10X/6X DVD-RAM 12X Writer 2MB Black OEM W/ SW
AMD Sempron 64BIT 2800+ Processor S754 Palermo 1.6GHZ 256K L2 Cache 90NM SSE3 Retail Box
Western Digital Caviar SE 80GB SATA 7200RPM 8MB Cache 8.9MS Hard Drive
BenQ X-TOUCH 805 Wireless Keyboard Mouse PS/2 Combo Black
ASRock K8NF4G-SATA2 mATX S754 GeForce 6100 DDR PCI-E16 SATA2 RAID Video Sound LAN Motherboard
Thermaltake TR2 W0070 430W ATX12V V1.3 24PIN/20PIN Power Supply Dual 80MM Fan /W 6PIN PCI-E
Crucial Ballistix PC3200 512MB DDR400 Unbuffered Memory 184PIN DIMM CL2-2-2-6 64MBX64
I will be using my 19 inch widescreen lcd and monitor speakers that I aready have. And also using onboard video card till I can find a better deal.
