Son of Shadow,
For a first timer, it would be worth 15 minutes of your time to peruse the user manual (and watch the YouTube video). Have you seated the DRAM correctly? Look up what the POST code error means in your manual. We are here to help
you learn, which means we will point you in the right direction. You still have to figure it out. A efficient way to test a build would be outside the case.
- Seat the CPU and HSF.
- Plug in one stick of RAM.
- Seat the GPU (if your CPU has on-board video, skip this step)
- Connect ATX 24pin and EPS 8 pin power to the motherboard. All connections snap in securely.
- Connect KB, mouse, monitor.
- Turn ON PSU and then turn on the MB by shorting pins 6 and 8 (page 29 of the manual) with a screwdriver.
I'm going to put on my professor hat for a moment to give you a bit of advice. Most people stop after assembling their computer. But, if you really want to learn about your machine, it would be worth exploring a few details. For example, do you know what the pin assignments on the ATX connector are? The difference between PCI and PCI Express? NVMe vs SATA in terms of lane assignments? There is a lot to learn, if you are so inclined. If you are curious, start by picking one subsystem a week, say "power connections" and learn about it.
Happy learning!
