- Nov 16, 2016
Hi all, I'm pretty sure I will be going with the Extreme6 motherboard, 6600k and H7 (might upgrade later). But I can't figure out what memory to get. I'm especially confused by the latencies.
I know CL 15 is supposed to be faster than 16 or 17 and I read somewhere that a 3000 CL15 should be equivalent to a 3200 CL16 in terms of speed. Is that true? I'm having trouble deciding what to focus on.
Should I go with higher speed like 3200 even if latency is high, or should I go with lower latency even if speed is less?
Also, could someone explain this? I was just looking at 2 different sets of DDR4 3200. One was 16.16.16.36 and the other 16.18.18.38. Both are listed as CL16. Is one of these better than the other? Thanks so much.
If anyone wants to suggest a brand I'd really appreciate it.
