Should I reinstall XP?...
Crispy
Midwest
Well I have just spent the past 2-3 days OCing my PC. I'm sure I could do more but I'm pretty happy where I am. The thing is during these past couple days I had OCCT freeze up on me twice and had it lock up on me acouple times loading into windows. I haven't had any errors and I pass memtest,SuperPI,OCCT. Should I not worry about it? Thanks
:shrug:
I think I'd probably suggest running chkdsk on the volume (Start | Run | Type cmd, and click Ok | At the command prompt type chkdsk /f c: (the /f switch fixes any errors found on the disk), and hit ENTER... chkdsk will be scheduled to run on next boot if you say YES to the prompt.
