- Jul 15, 2013
ok so right now i game on a socket 1366 PC the specks for my PC are in my signature below.
my cpu is overclocked to 4.315.57Mhz at 1.344 volts on the vcore. ram was able to be run at stock speeds so no overclock on the ram which im fine with. my GPU is an EVGA 1660Ti black edition. i dont think i can overclock my cpu any higher without increasing the volts beyond what i consider safe for 24/7 gaming/computing, temps while gaming max out around 50-55c they idle around 40c using 3 5.20mm/H2O high static pressure ek vadar black fans.
below is a sample list of some of the games i free just in case they might help you answer my question
all tomb raider 2013,rise of the tomb raider,shadow of the tomb raider
doom 2016
the witcher 3
the metro series to name a few
i game on a 1280x1024 monitor that i bought used because its all i could afford at the time
my question is do i keep my CPU and GPU even tho socket 1266 is old or do i keep the GPU and upgrade to a better intel CPU?
i know there is AMD RYZEN but my cpu aio cooler is already configured for intel board and i dotn have the amd mobo clips for my aio i gave them away hence why if i upgraded it would be to intel
i guess the reason im asking this is because im unsure if my current setup will hold well in games seeing as how i had to swap out my RX 470 to the 1660Ti just to get shadow of the tomb raider to run at decent frame rates?
thanks for your time
doom 2016
the witcher 3
