Source Engine Games Chugging
shard
You Should Make a Wish!
On the system in my sig, Almost all source multi-player games chug whenever I see an enemy. No this is not me sucking, I used to be able to play quite well. Now whenever I go around a corner and somebody is there, I chug and miss frames. This is with a ping of 40-ish and all my rates are up to date. Also using a config found here. Mainly concerning CSS atm. TF2 suffers from it too, and get it off and on with L4D1.
Code:
// Casey's Config v2 (CAL compliant)
// Updated for new season by CAL|Stone
// Updated 01/23/07 - Added misc settings section
//_Set Netcode vars_
cl_cmdrate "101"
cl_interp "0.01"
cl_interpolate "1"
cl_lagcomp_errorcheck "0"        // Disables lagcompensation error checking, only needed if you're having any registration/loss/choke problems.
cl_lagcompensation "1"
cl_smooth "1"
cl_updaterate "101"
rate "25000"
//_Set MP vars_
mp_decals "0"            // How many player sprays will be shown.
//_Set Client vars_
cl_drawmonitors "0"        // Disables the rendering of ingame "monitors" which contain 3d rendered images.
cl_ejectbrass "0"            // Disables brass ejection
cl_forcepreload "1"            // Forces the game to load all texture and model information into memory on map load.
cl_phys_props_enable "1"        // Enables phsyics props.
cl_phys_props_max "50"        // Maximum amount of physics props allowed.
cl_ragdoll_physics_enable "0"    // Disables ragdoll.
cl_restrict_server_commands "0"    // Compatible/needed with serverplugins
cl_show_splashes "0"        // Disables water splashes.
//_Set Render vars_
r_3dsky "0"            // Disables the rendering of 3d sky boxes.
r_decal_cullsize "9999"        // Any decals under this size are not rendered.
r_decals "0"            // Disables decals.
r_drawbatchdecals "1"        // Enables the rendering of decals in batch.
r_drawdetailprops "1"        // Enables the rendering of detail props.
r_drawflecks "0"            // Disables the sparks and dirt from bullet impacts.
r_drawmodeldecals "0"        // Models decals (i.e. blood).
r_eyes "0"            // Disables eyes in models.
r_lod "-1"                // Different level of details on models. -1 = Variable at distance. 0 = None. 1 = Minor. 2 = Less minor.
r_modellodscale "1.0"        // The transitioning power of LOD.
r_occlusion "0"            // Enables the Model Occlusion system.
r_propsmaxdist "100"        // Max distance at which props are rendered.
r_renderoverlayfragment "0"
r_rootlod "2"            // Base lod of the model in the memory.
r_shadowmaxrendered "32"        // Max shadows the game will render.
r_shadowrendertotexture "1"        // Rendered the shadow texture causing it to match the player model.
r_shadows "1"            // Enables shadows (Change be disabled for additional performance.)
r_teeth "0"            // Disables teeth in models.
r_waterdrawreflection "0"        // Disables the rendering of water reflections.
r_waterforceexpensive "0"        // Forces cheap water.
gl_clear "0"            // Disables the gl_clear convariable.
props_break_max_pieces "0"    // Disables prop fragmenting
//_Set Materials vars_
mat_antialias "0"            // Disables the use of multisampling to smooth out edges.
mat_bumpmap "0"            // Disables bump mapping.
mat_clipz "0"            // Disables optimized Z-Buffer rendering.
mat_compressedtextures "1"    // Disables texture compression. Users with low amounts of system memory should turn this on.
mat_disable_bloom "1"        // Disables bloom effects.
mat_hdr_enabled "0"        // Disables HDR.
mat_hdr_level "0"            // Double Disables HDR.
mat_mipmaptextures "1"        // Enables the use of mipmapping to make textures look smooth.
mat_monitorgamma "1.6"        // Lower the number the brighter the screen. Only works in fullscreen.
mat_picmip "2"            // Changes the resolutions of textures when they're loaded into memory. May improve FPS on graphics cards with low memory sizes.
mat_reducefillrate "1"        // Reduces the fillrate when the game is run in DXLevel 8.
mat_specular "0"            // Disables Specularity on objects.
mat_trilinear "0"            // Disables the use of Trilinear mipmapping.
mat_wateroverlaysize "8"        // Sets the resolution of water distortion. Must be multiple of 8.
//_Set Violence vars_
violence_ablood "1"
violence_agibs "1"
violence_hblood "1"
violence_hgibs "1"
//_Set HUD vars_
hud_centerid "1"            // Centers player IDs
net_graph "3"            // Enables net_graph (Required in SS round)
net_graphpos "2"            // Adjusts netgraph position-set between 1 and 3.
//_Set Misc settings_
cl_downloadfilter "nosounds"        // Disables annoying pub sound downloads
fps_max "101"             // Caps framerate. Set to max monitor refresh rate + 1.
jpeg_quality "100"            // High quality screenshots
clear
echo _Casey's Config v2 (CAL compliant) loaded_
Constantly doing 150-200fps with no drop, including using FRAPS benchmark to track it.
No idea what to do. Any tips?
Not sure if each game uses its own separate files for the source engine, but have you tried reinstalling the game? Perhaps there are some corrupt/bad graphical files? Doesn't make a whole lot of sense if you're ping is that low and have a constantly high fps.
Just barely reinstalled CSS yesterday.
