Alright, I'll see how it goesVrykyl said:it depends - if you make your own duct to eliminate the deadspot youll maybe see temps 4°c higher than with a deafening fan...but at least youll have your hearing!
Wow, that looks quite good! Can you explain how you did that? Is that black bracket type thing that is holding the fan included witht he SP-97 or is that something you rigged up?Vrykyl said:Iv done just this - tho i found that cos the wire clips have to slip into the spacer fans screw holes to hold it you thus cannot use an adapter on top - theres nothing for it to screw into - you cant hold a 120mm+spacer on with wire clips - its just to heavy and the canter of gravity if way off. I solved this issue with this arrangement -
Vrykyl said:That bracket was made for me by a friend just for the job and built specifically to fit that exact fan - 120mm delta (its thicker than a normal fan) at 190cfm....
