- Mar 31, 2010
Hi, I'mhaving some rather peculiar computer problems. I started up starcraft 2 and it died on me - nothing out of the ordinary, I've had this issue before. However, today, something new happened. It didn't just crash on me, but it also BSOD on me. After the BSOD, I went back into Starcraft 2 to try to see how bad the error was and this time, the whole computer froze upon entering the main menu (this has not happened before) and then it BSOD. It froze in a strange manner, it started to freeze bit by bit, first the sound froze and the mouse was movable, then the mouse froze and the display went all wierd and after that froze for good. I tried ctrl alt del it but it BSOD at that point.
Here is where it gets even more wierd:
I have 4 Hdds and 2 RAID 0 partitions. This all happened in my second installation of windows. So I rebooted and went into my main installation of windows because I decided to finally reinstall the whole computer and install windows and linux. So I went into my main Windows partition and BSOD a short time after I started copying some files to my backup external. This BSOD felt very similar to the one I had just experienced when getting into starcraft ON A DIFFERENT PARTITION!
Coincidence? Well, I thought so, so I then deleted all partitions and created 3 new ones, one for linux and 2 for windows. I tried to install linux first and during the installation process, an error popped up suggesting some files were corrupt and the isntallation would not proceed. The probably causes, damaged disc (unlikely as it's brand spanking new disc with no scratches on it), or optical drive failure (haven't confirmed this yet, will do so soon but I don't think this is the issue either).
Anyway, so after unsuccessfully trying to install Linux, I decided, ok I'll go install Windows on my main partition. I go into the installer, click install, then an error pops up "verify that the installation sources are accessible and restart the installation".
These two installs were in RAID configurations on seperate drives. So I have no idea what is going on, does this sound like a hard drive problem? If so, how can it have spread from one partition to another?
If it doesn't sound like a hard drive problem, what else could it be?
EDIT: The error that popped up when I was installing Linux was an input/output error which the dialogue box suggested may be due to a faulty disc or dvd drive or hard drive.
I tried installing it again using my Blue Ray drive (not my DVD drive which I used during the first install attempty) and the same error popped up at the same spot, so maybe it is a DVD fault but I'm not sure, as I said, it's a brand new DVD disc. What are the chances that the same error pops up in the same spot if it's a hard drive fault?
