Submerged Water Cooling Setup
customrig
Wethersfield, CT
I already know how an inline water cooling system works but I was wondering how a submerged pump setup would work. If someone could explain what to do with the pump resivour that would be great.
dream caster
water pump is inside the reservoir, below water level, then it sucks water and sends it to your radiator, water tubing then go to water block(s) and then to reservoir again.you must take care that air does not get sucked into pump and water circuit.
glass
finland.
right. the pump just sucks water from where it is.
the out-line of course needs to be connected..............
