I am running windows xp and had recently installed kaspersky on my pc. I wanted to go back to before this was installed, so did a system restore which worked. However, I then tried to open system restore again in order to undo this action, but it had disappeared!! My help centre has also disappeared and my "search" facility, along with who knows what else. I have googled this and something which seemed to work with someone else is that they happened to have made a registry backup with a link to their desktop, so they merged the registry back up into the registry and system restore came back. However, I do not have such a registry backup - would my pc have automatically saved one somewhere maybe?
Something else which is probably relevant is that if I go to control panel>admin tools>services there is nothing there, just a big block of blue where there should be entries of some kind.
In event viewer there were lots of errors one of which was 7023 and directed me to http://support.microsoft.com/default.aspx?scid=kb;en-us;328213 when I double clicked on it. I have downloaded this hotfix, but all that was in the download was a txt document, not the hfx.exe itself, so that wasn't any help.
From the info I have been able to get from google, I think it is probably a registry error. Should I download registry-mechanic which says it can repair the registry?
Please can someone suggest something to get this sorted out?
Many thanks in advance for any advice.
