- Mar 12, 2002
Ok well with the recent death of my 2x GTX 460s the Green Gorilla has been sitting in a closet.... Anyway so I had some free time today and decided to pull the thing out and dismantle it since I had to check all of the components. So on close inspection I discovered that during the shuffle apparently my NB waterblock made contact with one of the resistors on the chip which blew out some chip nearby effectively killing the motherboard...
While its certainly unfortunate that this happened I do get some amusement from the fact that the gigabyte factory HS for the NB had a rubber ring around it to prevent this from happening. How a major WC company didn't account for the fact that sometimes people install tubing pulled very tight and include this is beyond me.
Anyways since I had the rig fully disassembled I decided to finish up a few of the things I left incomplete during the first build, since I have extra time and all.
So In the 21'st century during the age of the dremel it seems that unskilled un equipped youths seem to think that case modding is beyond their reach. I say to you NAY! Before the dremel we had hand tools. Things like sheet metal cutters and files(not the digital kind). So in order to remind people of the old days(and because my dremel needs a new collet) I decided to finish modding this case by hand.
Before
After trimming
After filing
Before
After
Now if you cant operate a pair of scissors and a file maybe you should go back to kindergarten and pay more attention, because as you can clearly see even simple tools can yield excellent results. I have opened up another 10-15% of the surface on my top radiator which should help temps, and NO MORE SHARP EDGES!!!!! Before today I have cut myself atleast 10x on this case, no more, I finger tested all openings and filed them down until nice and round.
In light of the dead motherboard and 2x dead GPUs I decided to take a volt meter to my PSU just to verify that the readings were consistent, which they were. So I drug out my old HTPC board a cheapo Biostar A770E. Sadly it wont support my 8120 but oh well. So I have drug up my sempron 140 which unlocks and my old 9800GT 512MB card, because any desktop is better than working from a laptop(even a nice HP Mobile Workstation like mine) and got this put together.
Since I had it all apart I decided to also go ahead and install my UV CCFLs. Ive had them since before I started the GreenGorilla but never had a chance to install them. As you can see in the picture above I installed the on/off switch to the inverter in the CM 690's weird *** vertical pci slot. So now to some under the desk shots!
Im taking it easy on this rig(kinda) sofar, Ive got my mushkin blackline 1600(8-8-8) running 1333(7-7-7) currently on stock 1.6v. I did unlock the 2nd core on the sempron after an hour of prime 95 @ 3.35Ghz which the core never got over 36C. I just updated to the nVidia 300 beta driver so hopefully I will find stock+official HD texture skyrim playable.................................... Sofar though i'm just happy to be sitting at my desk. Once my GPUs come back and I replace the motherboard Ill be able to find out of the 8120 survived all of this. If it did I say props up to AMD because my FX has been through hell and hasn't complained yet.
Before
After trimming
After filing
Before
After
