Pft, the thing that bothers me is people keep raving about power use, and then they go and buy a bronze rated or lower power supply. If it really is that important then they'd buy a platinum or gold rated PSU. If touting it as an advantage and then buying an in inefficent PSU it sort of indicates double standards..... Of course, my buying AMD and then buying a Platinum rted PSU indicates double standards on my behalf too
I figure that using a platinum rated unit should even out my power use a little.... I'm with AMD for now, will upgrade to a FX8350 soonish.... Getting curious about Intel chips though for some reason I enjoy buying from the underdog.... If VIA would just release something half decent then I'd buy something from them too. They're the only other x86 licensee after all
