- Sep 18, 2005
- Virginia
Ok I thought so, just wondering. Anyway, what graphics card are you planning to purchase?
deathman20 said:Oh case it should be in my sig, if it isn't its a Antec Super LanBoy
Ya Core-1 is giving me the issues. Core-2 is perfectly stable at 1.456v in windows though. Bumped it up to 1.488V windows (1.525V Bios) and see where it takes me.InfiniteThought said:According to the SN, your X2 was fabricated about the same time as mine.
Mine does 2.6GHz at 1.456, however core-0 is only 4:30 Prime95 stable. I have to jump to 1.48 to get core-0 stable at 2.6Ghz.
PWatterson said:Does where the cheese heads live = Somewhere in Wisconsin (BIG packer fan)?
Vrykyl said:looking good deathman - we always seem to end up with almost identical rigs Im afraid I didnt have the patience to wait for the x1800xt to arrive tho
Can't find anything for results of my last CPU man. I know I didn't have any PI results though it was all sandra scores and results. It did scores slightly better then the 3.2Ghz P4's though back when I did have the tests, which now is nearly 2 years ago.
Chaos_Being said:Bummer. Although I could always do those benchmarks on my rig (since it is virtually the same as your old one) and compare them to what you're getting with your new setup.
Sounds like things are coming along nicely How do you feel it compares now with your OC vs. your old machine?
Cemson said:cool overclock result.
Do u feel it faster than Intel system?
deathman20 said:Well tried testing it again last night. Core 1 is the iffy core totally. I tried taking her to 2.55Ghz and it crapped out @ 1.55V Bios and I already know the core fails @ 2.6Ghz with 1.612V (1.55 * 104%).
Now either prime doesn't like it all that much, which is possible, but everything else I try seems totally stable. And it always seems to die around the 55-65min mark on that core when I try going higher.
Anyone suggest another program to test stability? Would Super PI (2 instances) running a 32M bench be a good test to try?
