- Jun 10, 2003
- Eldersburg (Sykesville,) Maryland
Title says it all. First of all, here's what I'm planning on using alongside whatever cpu I choose (I have these nailed down almost 100% at this point):
Motherboard- Epox EP-9NPA+ SLI
RAM- 2x1gb G.Skill Extreme Series PC4000
PSU- OCZ Powerstream 520w
Video Card- eVGA 7800 GTX
Heatsink- ThermalRight SI 120 w/ Panaflo 120x38mm Med. speed
My goal is 2.6ghz, so I can be at FX-55 speeds. More would be better
My initial plan was to use a X2 3800+, but now I'm very tempted by the DC Opterons. There are a few caveats though. I'm a little uneasy about the 165's multiplier of 9, I"d have to be able to hit pretty high HTT to attain my goal. Also, the 165 is going to be a pain to obtain, its out of stock pretty much everywhere now so I'd have to backorder it. And who knows what the next batch may be capable of.
The 170 has climbed back up in price above $400, so in reality that pretty much kills it for me. That's why its a "maybe," and to be honest its a pretty far maybe.
The other choice is the X2 3800+. Cheap(er than the 170 ), easy to obtain, but has less cache and "seems" to overclock less than the 165- or is that just Opteron hype?
Basically, if you were in my shoes and had the hardware I listed above, which would you want- X2 3800+ or 165? Or 170, if its really worth the high cost?
(There is also of course the option of single cores, but seeing as how I am already spoiled by HT, I think a normal single core would just drive me nuts. Dual core seems to be the logical choice for an upgrade, to me anyways.)
