you guys pick 6176 SE OR 6276 ES let me know soon
proj 6180se 6276es
8101 450K 600k
8103 600k 800k
both are OCs 6180se is at 2775 and 6276se is at 3600
only ES can be OC retail you will be running at 2.6ghz max
There is no bios for ES OC. Just change the muliplier per se ... you can find lots of info on this thread _http://hardforum.com/showthread.php?t=1715566&page=10
Warning: If you are not careful, burning wallet is exactly what it will be..... for example you will need 1250W PSU for this beast and many more things
ok pulled the trigger ordered 8 6276 ES
i will feel this on pay day LOL
The HAF X and HAF 932 will both accommodate a Supermicro AMD H8 series 4-P G34 board. I'm using both cases with 4P systems. They are very good coolers. It's a tight fit for both cases, but they work very well with modifications.
VM/ESXi work fine with OCing, as long as your oc is stable
