countermods
Disabled
- Dec 10, 2002
just got 2 of these they are from pctoys they are 92mm tornado maxx f5 199cfm each and not to loud either any one know where i can find the tornado f5 in an 80 mm
countermods said:no it says right on the side of the box for specs weight 187 grams rated voltage 12 volts rated power 12.5 v rated current 1.0 amp airflow 199 cfm fan speed 4800rpm noise level 56.4 db/a bearing type double ball bearing
nerdlogic said:
If so, that's the pctoys equivalent of the Vantec Tornado manufactured by Sunon. (BTW, It says 119 CFM on the site)
You could've gotten the same fan for a lot cheaper. SVC has good prices on cooling items.
nerdlogic said:Oh, I thought the tornado was manufactured by sunon.
Penguin4x4 said:
Actually all Vantec fans are made by other companies. They simply put a Vantec sticker on em, package em, and send em out.
CrashOveride said:trust us. its NOT 199CFM no matter what it says, its probably a lie or a typo and it is like just labled by PCtoys like waht vantec does
countermods said:ok guys listen up this is aa pctoys tornado f5 series will put up pic later it says on side of both boxes 199cfm and yes it is loud but im used to it i have 2 air conditioners in my room running 24/7
CrashOveride said:
those lamos!!! thats why you should go with delta but htey dont make a 92mm version my Delta is 80mm and 80CFM
countermods said:not a typo called pctoys and they confirmed 199cfm for the 92mm tornado f5 in the orangeish yellow box
