- Aug 13, 2001
- Deep Blue Sea (Maryland)
using the 9x.xx forceware driver, there's noise reduction and sharpening under the video section of the driver setting app.nd4spdbh2 said:you can do that???? where at?
LandShark said:using the 9x.xx forceware driver, there's noise reduction and sharpening under the video section of the driver setting app.
mr. roboto said:i'm tellin ya, try out powerdvd
nd4spdbh2 said:well you see powerdvd produces no where near the picture quiality i can get out of ffdshow and purevideo
soulrider4ever said:yea, but according to your previous post you used powerdvd 6, which wouldn't use the hardware acceleration from purevideo. You'll need version 7, which should obviously have a substantial increase in IQ using purevideo.
Also of note, don't forget to enable inverse telecine in the control panel, very important!
nd4spdbh2 said:oh yes... i did how ever forget to mention that i dowloaded powerdvd7 trial and saw no image difference.
ima get to reformatting my htpc soon
btw for the FFDshow download... how in the world is rev .610 a newer version than .736?
http://www.afterdawn.com/software/video_software/codecs_and_filters/ffdshow.cfm/rev__610__20061201
b/c it's still beta.nd4spdbh2 said:oh yes... i did how ever forget to mention that i dowloaded powerdvd7 trial and saw no image difference.
This is the latest stable version of this software. There is a newer beta version (rev. 740 (20070105)) available. The beta version might have new features compared to the stable version, but may also be more unstable.
LandShark said:b/c it's still beta.
soulrider4ever said:Let's get a lil tutorial on how to get that setup with mpc, and screenies plz!
Phrenetical said:Actually im sort of surprised you guys didnt know about MPC, iv been using it for a couple years now, and since ffdshow came out and the latest divx codec its been even better.
@ nd4spdbh2 : are you able to do a couple screens of picture quality through mpc and say your older setup?
Glad its working for you but bro
