- Jul 30, 2014
Hi there,
I have a few things I would like to change in my Windows 7 SP1 Ultimate.
First and main issue is I want to turn off those annoying thumbnail previews you get when you highlight something on the bottom of the taskbar. I have tried the gpedit.msc way which doesn't turn this function off. I know when I turn off desktop composition it will then disable my colored toolbar the standard color which isn't changeable.
Basically what I want is to keep my custom colored toolbar with the nice looking windows 7 toolbar and have that super annoying thumbnail preview thing turned off (It makes it annoying when gaming).
I would also like to know if there is a way to make it so when I click something on the taskbar I can have the traditional maximize and minimize function in the right click rather than the annoying new thing.
Also another thing I have noticed and would like help with is the text on screen it all seems to be looking smooth but then there is abit of it where it looks like it has not been smoothed out its really obvious and I don't understand what is causing it have done full win 7 updates aswell.
Regards,
Time-Bandit.
Regards,
Time-Bandit.
