- May 31, 2009
- Citrus County, FL
http://www.cnn.com/2011/TECH/innovation/04/25/seti/index.html?hpt=C1
Anyone know anything more about this?
That's correct. All the SETI@Home data comes from the piggy-back unit at Arecibo. The article was slightly misleading that way, lumping the Arecibo time into the other arrays in Australia and West Virginia. SETI doesn't actually "share" telescope time at Arecibo, except every 4-5 years for specific observations.We participate in SETI@HOME which seems to have no relationship with the work going on with the Allen instrument.
http://www.overclockers.com/forums/showpost.php?p=6304545&postcount=3Currently, Project SERENDIP data is what we process using SETI@Home. ... Project SERENDIP uses its own receiver mounted above the main receiver at Arecibo. Instead of using actual radio telescope time, SERENDIP processes radio signals from wherever the dish happens to be pointed and doesn't interfere with normal dish operations. Since SERENDIP is an all-sky survey individual targeting of stars is not required, so this “piggy-back” method of observation is an ideal solution combining the valuable observational power of the Arecibo dish with a relatively low-cost data collection method since individual dish time is not needed.
SETI@Home is always looking at whatever patch of sky is being observed but it's never been clear to me whether SETI is just copying the data being gathered (by whomever) or if they have their own receivers picking up different frequencies than what is being observed at the time. I lean toward the latter but haven't seen anything definitive to back up that feeling.Okay so what I'm getting out of that is that the data we get from Arecibo is just basically a mirror image of what someone else has the array pointed at. Seti@home doesn't get to pick and choose where they're looking in the nights sky they just get whatever someone else is looking at and works off of that data?
When Dan Werthimer and David Anderson launched SETI@home in 1999, SERENDIP had already been in operation for two decades. At Arecibo it had its own dedicated radio feed, used exclusively for SETI purposes. This arrangement suited SETI@home very well, and the new project took full advantage of the infrastructure that was already in place for SERENDIP. For several years the two projects shared the same radio feed and analyzed the same data from space – each in its own distinct way. Finally in 2005 they parted ways, when SETI@home was adapted to the new multi-beam ALFA receiver whereas SERENDIP continued to operate with its own dedicated radio feed.
Technically, since Werthimer's group will at no time be controlling the telescope, SETI will still be "piggy backing" on the observations of others.
Man, I didn't realize I had gotten so far behind in my reading. Sorry to lead you astray.
Good links, though, and where I did most of the research for the History article I wrote. At one time I was a TPS member and ran the original S@H screen saver for a couple of years.
I like it - but it's sad, too ...Don't know if everyone has seen this, an interesting 'info-graphic' on the relative costs of the SETI program.
