VCCSA is for the imc but a lot of people automatically group it with VCCIO when talking ram oc-ing.
You always hear " Bump sa/io to 1.25/1.20 " or something along those lines. Like they're integrally connected.
From below it appears io may not be relevant for ram freq or timing oc.
For ring, pcie etc. io is needed, but is it also relevant for ram ?
Does ram make use of the In and Out that vccio powers ?
Article section :
" VCCSA: Starting with the second-generation Core i processors (“Sandy Bridge”), the VTT voltage was renamed to VCCSA, and is called “system agent.” It feeds the integrated PCI Express controller, memory controller, and display engine (i.e., the “2D” part of the graphics engine).
VCCIO: Available starting with the second-generation Core i CPUs (“Sandy Bridge”), this voltage is used for feeding all input/output (I/O) pins of the CPU, except memory-related pins. On CPUs that have this voltage, it is also used to feed the thermal control bus (PECI, Platform Environmental Control Interface). "
Article section :
