theELVISCERATOR said:
and still slower than two 36s raided but access is quicker....
burst speed less than half
Not slower then my 36 gigabyters:
http://www.ocforums.com/showthread.php?t=346936
Vio1 said:
theELVISCERATOR: 172.5mb burst speed is impossible ... the most your computer could do is 150... or is it 120mb? I dont remember.
Correct if using the standard 32bit PCI bus we all know and love (it's around 133MB/s, and I got 129MB in link above).
Incorrect if using 64bit PCI buses (i.e., my previous Ultra320 mobo I had), it goes far beyond that. Servers I've setup with RAID0 spanned across 4 drives in Ultra320 is blazingly fast!
My previous motherboard had dual Ultra320 scsi controllers (dual P4 Xeon mobo). Even though I was using only Ultra160 drives, I wanted more.
Since you're new to scsi, the rule of thumb is this:
SCSI/SCSI2: 20MB/s, SCSI2 allowed bursting to 40MB/s on the bus
U/W: 40MB/s substained, possible burst to 80MB/s (I've personally seen 148MB/s on these, back in 1998!)
Ultra160: 80MB/s substained, possible burst to 160MB/s (I saw ~140MB/s bursting on my previous 7,200rpm drive)
Ultra320: 160MB/s substained, possible burst to 320MB/s
And they are coming out with Serial SCSI later next year, or might be out now for Ultra640 or something like that (haven't kept up with the news lately).
And then there's Optical drives... Do I need to keep going up in burst speeds that are possible?
Looking at your speeds, I'd say yours is rated right about normal. SCSI really shines on RAID in PCI64 bit slots.
Across two channels (each PCI 64bit path to the process/memory is individual, to allow max through-put PER slot!), I've setup several RAID 0, and 0/1 combinations. Putting a drive on one channel, and a 2nd drive on another channel splits the data packet across two true 64 bit paths to each controller. I've seen throughput in Unix across my servers using 4 Ultra320 drives (two on each controller, two controllers) around 420MB/s if I can recall. It was insane! Instant write and read.
Btw, if you went through the expense of Utlra160 why didn't you just get an Utlra320 card? Humm, now that I think about it I don't think they make Utlra320 cards for standard PCI 32bit slots, only 64bit slots.
Should have gotten a controller with write-behind cache.
Mucho faster!
After a decade of only using SCSI drives at home, and now I wanted to get into the overclocking world, I decided to dump SCSI and just go SATA. Yes, I can notice a little difference (especially the CPU usage now). But for something less then 1/2 of the cost for RAID0 I'll for these days. Now that SATA RAID is faster then U/W that I was on for many of years... And swore if things are faster then U/W, I'll switch.
So, I went from SCSI after 8 to 10 years of use to SATA. Hey, my pocket book was very happy with this upgrade.
