Joeteck
Retired
- Oct 5, 2001
- Long Island
you have to click, "host device" first, then it'll ungray connected & connect @ power on
client device means = map my local CDROM accross the network for the remote VM to use.
Not a problem at all =).
Any iso burner will work. Pop in your cd, fire up the iso burner and then copy the iso over to your host. Easiest way to do this is...
click on your host
click on 'summary'
you'll get something like this:
doubleclick on your datastore, it'll open up datastore browser. you can upload files, create directories.. all that.
If you really start working with moving files around, you should open up SCP in the firewall and transfer this way. I can show you how to do that sometime.
Cant check off CD-rom connected...
