you could mount it along the bottom of the case. but you might have a problem clearing the motherboard. (you would also need to cut out some of the bottem of the case to allow airflow.
I cut up an old CD-Rom Drive to use as a mounting bracket for my BlackIceXtreme2 Radiator in my armor. Have a Look
Bracket installed
Mounted in Case
Provided you are only Installing a Fan Controller and a DVD-RW drive, and you can come up with a Creative way of moving your power and reset switches you can make it all fit. Here is the front end shot of my case
At the top i have my DVD-RW drive, then my Cooldrive6, Cooldrive lite, 6-Bays taken by my radiator, then my 12v/7v switches, Switches for my lights and I used some Vandal switches for my Power and Reset and installed them in the very bottom of the front bezel.
