airspirit said:AXDA2100DUT3C 9724884280420
JIUHB 0308VPMW
That is what I got from Newegg the other day on an order. The thing caps at 2320, and is STABLE at 2150 or lower. I'm running an NForce2 board with cooling mods on the bridges, Corsair XMS memory, and high end watercooling. That chip never saw north of 48C (oh, did I mention it is a full 8-10C hotter than my old 1900+?), so heat isn't the limiting factor here. I'm really *****ed, and I'm going to be ordering another one in short order. Until Newegg runs out of those POS chips, I would avoid them like the plague.
xmonger said:I got this same chip from Newegg. (ordered last Friday and received this past Wed 4/9)
Very disappointed. Best stable is 2.041 (157*13) @ 1.7 vcore. It does not run that hot however, 43 C under full Prime95 load. This is with a cheap Glacial Tech 2500 pro heatsink/fan and the included thermal pad.
I'm running this on an MSI KT3 Ultra 2. Will the socket wire trick unlock the lower multipliers on this board/chip? I don't want to do this/ reinstall and find out that it won't work. I might turn it into a keychain at that point.
Xmonger
airspirit said:Are you sure its the board? It could be that this batch of chips do weird things with the mults. As I said, mine does the low range + 13x, when that should be impossible (from my reckoning).
justanoob said:i just orderd my xp2100 from newegg 2 days ago. i got it the next day (i live 20 minutes from new egg) i just raised the v core to 1.8 then raised the FSB to 166 and i instantly had an xp 2700
runs flawlessly maxload is 45 C on air cooling.... i would go higher but i like only using 1 fan![]()
