Here's what I have
3x GPU, 1 CPU, 2x 480 Rads, 1x 240rad, 1000D case.
I have one pump+res combo and one pump only. Which one should I do:
1) res/pump -> 2nd pump -> rad 480 #1 -> rad 480 #2 -> CPU -> rad 240 -> GPU #1 -> GPU #2 -> GPU #3 -> res/pump
2) res/pump -> rad 480 #1 -> rad 480 #2 -> CPU -> 2nd pump -> rad 240 -> GPU #1 -> GPU #2 -> GPU #3 -> res/pump
or some other order?
I ask because in any of these cases, when I initially fill the water in pump/res, first pump/res is covered, but till it gets water to 2nd pump, it will run dry for couple seconds and I hear that its a big no no. So what's the solution here? Should I manually first unplug the 2nd pump (turn it off) till whole loop is filled and then turn on the 2nd one? Or I shouldn't worry about couple seconds?
