- Feb 18, 2002
Summer hit and I started getting Internet Exploder errors pictured below due to unstable overclock @ 2.5 GHz. Had to lower the OC for the hot summer but now with the colder weather, it's back to 2.5 GHz again.
Interestingly the unstable OC did not affect Firefox. [side note: I switched to Firefox completely now that I found a Favorites add on. My many web links have custom icons and there's no way to convert those to Firefox Bookmarks so I sometimes used the Exploder but no more with PlainOldFavorites add-on.]
2.5 is nicer than 2.4 . Yeah, waitin' for X38-Penryn or Eaglelake-Nehalem or AMD equivalent to upgrade from nForce2-Barton. Didn't feel like redoing operating system partitions Drive Image files until I absolutely had to so I kept prolonging the upgrade. Nehalem is really the jump I want but maybe it will be compatible with X38 chipset, so I can do X38-Penryn then just swap out the Penryn with Nehalem and use the same Drive Image files, because it would be the same mobo chipset.
I guess it's now official that AMD will not have a horse in the race to compete as far as big overclocks go.
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12.5 = 2500 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.6 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with 80x38mm Delta EFB0812HHE fan
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower2 TPII-380
Five 80x25mm Case Fans
IQYHA 0348 SPMW
