hi all
I have hunted high and low for a good 120mm fan for the xp-120 and i think i have found it and was woundering what you think
its the
Enermax UC-12FAB
RPM 2300
Rated Voltage 12V
Rated Current 0.20A
Power Input 2.4W
Air Flow(max) 94.92CFM
Noise 30.10dB
its the lowest noise fan i could with the best air flow
i want the lowest noise but still a good air flow
the panaflow fans where abit more in the sound and abit less in air flow to
so i did not ot for that
so what do you think are these good fans or is there another
hope you can help still wating for the bracket for my 775 motherboard to ahhhh
can anyone tell me where to get this fan in the uk and the thermalright heatsink i have looked at overclcokers.co.uk and thay dont have the fan or bracket
thanks
its the
Enermax UC-12FAB
RPM 2300
Rated Voltage 12V
Rated Current 0.20A
Power Input 2.4W
Noise 30.10dB
thanks
