Hello everyone! I'd like to know what this is inside my CPU waterblock. Is this corrosion or algae inside my EK Nickel Plated waterblock. I've had this PC since August and just noticed the growth. I have a copper GPU waterblock but heard this isn't a problem with the nickel also in the loop. The GPU waterblock has no signs of corrosion or algae.
I'm using Mayhems X1 UV Clear Coolant. I flushed everything thoroughly with distilled water before assembly. Rad shake and everything!
I did add Meyhems Biocide Extreme when originally filling the loop. I have read that may not have been a good idea. Not sure.
My only other line of thinking is that it's from slow water circulation. I'm not sure about this or have any data. Because of space I needed to use a EK-DDC 3.2 PWM Pump instead of a D5. My last rig was on a D5 and I felt I got better flow out fo it. Not sure though! My PSU is a Corsair HX1000 watts which might be under-powering. I'll provide my specs below and look forward to hearing from everyone!
Rig
Motherboard: ASUS Code Maximus IX LGA 1151
Processor: Intel Core i7 7700k Kaby Lake CPU (delided)
Memory: G.SKILL TridentZ RGB 32GB DDR4 3866 (PC4 30900)
GPU: EVGA GeForce GTX 1080 Ti FTW3
SSD: Samsung 960 EVO Series 1TB
PSU: Corsair HX1000 1000 watts
Cooling
Pump: EK-DDC 3.2 PWM 12V
Res: Singularity Computers Protium – Medium 200mm
EK-Supremacy EVO CPU Water Block - Nickel/Plexi
Rig
Cooling
