where did my run go??
JigPu
Inactive Pokémon Moderator
Vancouver, WA
For XP:
Right click on the start menu, choose "Properties". Click the "Customize" button. If you're using the Classic Start Menu, make sure "Display Run" is checked. If you're using the XP start menu, go to the "Advanced" tab, and make sure "Run Command" (it's near the bottom) is checked.
JigPu
lilneel12
lilneel12
i don't have the option for display run in there, im using classic menu
and
when i did window key+r it gives me an error saying
restriction
this operation has been cancelled due to restrictuion in effect on this computer. please contact syst admin.
what??
I.M.O.G.
Glorious Leader
Rootstown, OH
Is this your own computer or is this someone else's?
It sounds like the system might be locked down.
If its your computer and you didn't change anything that might have caused this then you have another problem.
lilneel12
lilneel12
yea, its my comp and as far as i know, i didn't do anything, i searched it b4 and found a registry fix for it, and i tried it but it didn't work, so im stuck now
turd
You could try this
Do a search for gpedit.msc, when you get that click on it and go to:
userconfig | administrative templates | start menu and taskbar
then dclick on remove run menu from the start menu and see if that option is disabled or enabled.
Also are you loged on in an admin account?
lilneel12
lilneel12
yea i am in admin account
and the option for remove run was not configured so i set it disabled
didn't do anything, but i can't restart right now casue im prime testing. i will do it later to see if it worked, but i think it should have worked without restarting
lilneel12
lilneel12
but now when i press windows key+r the run pops up instead of an error
lilneel12
lilneel12
hey, now i just checked the options in the start menu properties and its back again, thanks for all the help guys
snafumaster
Software Jedi
South of Boston
There are some excellent third party tools that will aid in configuring options like this. A personal favorite of mine for Xp is "Advanced tweek Xp" There are some great and simple to use features in it. For a moderate skilled user, there are some that you may not even realize are options. One of the better advantages is if you don't like what youi did...it's just as easy to reverse your changes.
