Double Data Rate SDRAM is little more than a small evolution of current SDRAM technology. DDR SDRAM is capable, like RDRAM, of transferring data on both the rising and falling edges of the clock cycle. As such, its effective bandwidth is doubled. Consider standard 100 MHz DDR SDRAM:
(100 MHz Operating Speed) x (2x Rising & Falling) x (64-bit Bus) / (8 bits per byte) = 1600 MB/s available bandwidth.
As the numbers illustrate, DDR SDRAM, in conjunction with a 100 MHz FSB can provide bandwidth equivalent to that of RDRAM. Of course, like standard SDRAM, DDR SDRAM can be made to operate at a 133 MHz FSB as well.
(133 MHz Operating Speed) x (2x Rising & Falling) x (64-bit Bus) / (8 bits per byte) = 2133 MB/s available bandwidth.
When utilized with a 133 MHz FSB, DDR SDRAM can provide greater bandwidth than RDRAM. Thus, DDR SDRAM is able to achieve equal, or even higher, bandwidth levels while maintaining SDRAM’s lower latency.
