Hey guys,
Can you help me decide what cable to buy?
I just bought a refurbished IBM 21" P260 CRT monitor. There is some slight ghosting, and I suspect the supplied VGA cable may be faulty.
This monitor has both VGA and DVI connectors, as does my video card, a Radeon 9100.
I want to buy a new cable for the monitor to see if I can clear up this ghosting problem. I'm not sure whether to buy a VGA or DVI cable.
Would I get a better quality display if I go with a DVI cable, or does it make any difference?
Thanks
Thanks
