That is the same link I provided days ago...look at the summary for the closest res (1280x800). Also note that this review is an overclocked card versus the 6950 used is not. So even at his res, overall the 6950 is 7% faster... and at 1200p, 18%.ALRIGHT. so I see people suggesting different things, so I want to find out.
I did the following comparison:
at OP's resolution of 1360 x 768
with MaxPayne3. (OP's choice of game)
and guess what... http://www.techpowerup.com/reviews/Sapphire/HD_7790_Dual-X/18.html
looks like 7790 in fact does a little better there. (i m surprised)
so looks like there's more to this then just performance...
I must confess I don't play games that much, and my resolution is at 1920 x 1200.
but looks like if OP wants to use resolution of 1360..
then in fact 7790 better..
lower power, less noise, better performance, newer tech.
However, I will standby my choice where 6950 is a 'stronger' card, and will perform better at higher resolution.
OP, this is a case where you need to compare 'your games' and 'your resolution' to fit your need the most. here's a site for you. Good Luck!
http://www.techpowerup.com/reviews/Sapphire/HD_7790_Dual-X/1.html
and here is something more relevant.
which HAS 7790 dual-x AND 6950
and closer to your resolution, at one of the game example you asked.
How is that more relevant? That's one game. In fact, all two people in this thread supporting the 7790 have only posted results from the one game. Looking at those results (and seeing how the 7790 vastly outperforms everything else from the last gen), clearly indicates to me that something in that games coding is way more optimized for the 7xxx rather than the 6xxx, and that is definitely not going to hold true across the majority of games.
And from what ED mentioned:
This is a OCed 7790 vs a regular 6950, so the 6950 is on average just a tiny bit better at that resolution. Nothing hugely significant at all.
Correct. 6950 is the better performing card.
It seems its about 13% better than the 7790 across all the games that TPU tests...
http://www.techpowerup.com/reviews/XFX/HD_7790_Black_Edition_OC/26.html
Research indicates it doesn't really matter what card he buys because the difference is like 1-2 FPS because his monitor is a **** resolution where the GPU doesn't matter nearly as much.. Looking at every individual game I haven't seen a difference of more than 6-7 FPS.
Whatever your pro gamer mind thinks about why he doesn't upgrade his monitor...judging by the fact that he's looking at cards in this budget range, he probably hasn't upgraded his monitor because he can't afford to. Meaning, if he saves up, his next upgrade might be a new monitor. Or he'll use his TV, or whatever. Considering the 7790 falls behind at any reasonable modern used resolution to the 6950, I'd still spring for the 6950.
and yeah, let the Original poster buy 6950 which will clearly under perform in his resolution for games he might play and call it good advice..![]()
The only games the 7790 won were: AC3, BF3, and Max Payne 3 if you compared the stock 7790 to the stock 6950.
Have you never heard of future-proofing?
The original poster hasn't logged in since the day of starting the thread, which was a week ago.
Really I'm only arguing for the sake of arguing. Mostly because of your attitude that you're more right on games which are effing entertainment just because you get paid to play them.
Given the fact that I misread the graphs because I was going through quickly:
3 games that 7790 won
4 games the 6950 fell between the two (but you could just OC the 6950 and it would tie, if not regain the lead)
10 games that the 6950 won.
Even if you throw out D3, the 6950 still wins in the majority of games.![]()
