- Jul 27, 2010
- Maryland
The i5 is going to probably be faster if you massively overclock in the range of 4.5-5.0ghz which has been easily attainable with a good cooler. AMD, you'll be able to get cheaper motherboards and a close performance only if you get the 6 core CPU, the 4 cores can't compete with the i5 or i7. The problem with Sandy Bridge is that they had a big issue with their SATA controller so they did a huge recall on them. There still aren't any motherboards that you can buy online. You can wait for them to come to market which will be sometime in April I believe. They're making a fix and the new Motherboards will be fine you'll just have to wait a while. For AMD, get the CPU you mentioned and either this Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223 which is really amazing but doesn't have USB 3 or SATA 6 gb/s, or get http://www.newegg.com/Product/Product.aspx?Item=N82E16813157208 which has all the features and isn't as overkill with everything but still good enough for heavy overclocking.
