- Nov 5, 2013
- Ottawa, ON
Okay so I overclocked my i5 3750k to 4,000 mhz, 1.2v and the BIOS says that the idle temps are between 50-60c. I figure this is okay and I probably won't max the CPU on a stress test.
So, I do a stress test and monitor it on both Core Temp and SpeedFan and I get the following:
According to CoreTemp, I maxed the processor yet according to SpeedFan, I pretty much achieved the idle temps that were reading in my bios? I'm not sure at this point, which to believe. I don't want to max my processor under ANY circumstances so I want to make sure that it isn't happening. It also says in SpeedFan that my idle temps are 38-40c and in core temp it says they are 48-50c.
What makes me believe SpeedFan more is that my GPU temps are correct. My GPU always runs 35-40 idle and 60-65 on load. But CoreTemp has never failed me before...
I am using an ASROCK z77 Extreme 4 for a mobo by the way and am running the processor and GPU on water which is why I figured it went in the water section.
