I have decided, allthough this will not be done any time soon, that I'm going to get watercooling for my next system.
Unless anything unexpected happens like someone invents a cpu that doesn't put out any heat or overclocking is illegalized (ok, if I could still do it I would, but if it is made impossible I wouldn't have a choice) I'll be getting a nice cooling system with video, cpu and possibly chipset cooling.
But then there is the peltier.
I know it can make a difference but that difference in O/C is extremly small and will probably create a lot more problems than the extra performance it gives.
If you think it is worth it, tell me why!?
I can mostly see the problems with costs for a PSU for it, extra heat to take away with the waterblock and the condensation issue is a big one too.
