- Dec 23, 2009
- Burlington, Ontario, Canada
Hi everyone,
I am hoping that some of you can help me out with a problem I created for myself. I am pretty computer illiterate, but I can follow directions well and am self-sufficient when I utilize Google and common sense. That being said, not a lot of people are downgrading from Windows 7 back to XP.
I however decided to help out my sister and "fix" her slow, virus ridden computer by formatting (I have done numerous times before -- successfully) and happened to have just bought the W7 OS. Everything went like a charm until it booted up after a full install from format, not an upgrade, and the graphics card could not support the OS properly. The screen resolution cannot be changed and is beyond annoying. I have to have the taskbar on auto hide in order to click "next" in windows.
The issue now is, I would like to reinstall XP but the hidden partition in Disk 0 does not allow XP to locate the proper files in order to install.
I have tried loading XP onto a bootable USB drive, I have tried installing from the original windows xp disc, (Yes both times, the BIOS was set correctly). I have also tried assigning the partition a letter, working through DOS commands to make the partition NTSF.
I am worried I have royally screwed her and will need to buy a graphics card to make this all work.
I called Dell and they want to charge me for seeking Software help, or send me a new hard drive for $80.00. I went to future shop and the guy there was useless stating that it is impossible and I should just replace the graphics card.
I am desperate and am hoping someone can help. The Dell tech. support guy did give me one free tid bit and said they can guide me through an "advanced process" where in we use Dos to format the drive but after searching for something like that, I am left with command prompts for W98, W2000, WMe, WXP and Vista, but nothing for Windows 7 yet.
Any suggestions? This has been a week of trying and you guys are my last hope! Thank you in advance!
