I have spent the last week trying to figure out why windows runs like crap, minus the obvious reason that it is windows. This problem started a couple of months ago and I didn't have the time to diagnose the problem until last week.
Before I start, let me say that I have enough computer parts to build 2 computers. I have tried every possible combination to find a hardware fault, and it is just not there. Regardless of which parts I use, windows acts exactly the same. I therefore am 100% confident that it is not a hardware problem. And yes, I have tried installing windows on various hard drives and the result is the same. I even turned off paging to disk when I had 64bit windows with 8GB ram, and it still had problems. Also everything is at stock, until I can solve this problem. I've installed windows at least 12 times during testing, and used various install discs just to make sure it wasn't a bad DVD.
Here is the hardware:
CPU: E4300, Q6600
RAM: 2*2GB DDR2 800MHz: 4GB OCZ and 4GB Corsair
Motherboard: EP35-DS3L, P35-DS3L, P5Q Turbo
Video Card: 240GT, HD4890
Power Supply: 600W Huntkey, 450 watt Some Chinese brand
Harddrive: 32GB SSD (for OS) and 3 other HDD
Heatsink: 2 different big copper heatsinks with 2 big fans on each one, no heat problems (one is a thermalright, the other is some Chinese brand)
OK, with that said: Windows runs like crap. It lags/freezes constantly. It is most noticeable when using a browser (chrome, ie, firefox). It even freezes for a few seconds while I'm typing this. It will freeze when I switch tabs, scroll down a page, or for no reason at all. When I open programs, switch between folders, open a hard drive, plug in a USB drive, it lags/freezes enough to be a pain in my @SS. Also my girlfriend, or anyone who uses my computer, notices it enough to complain about how slow it is. While the hardware is not top of the line, it should be fully capable of basic internet browsing, and using windows explorer without problem.
I use windows 7 ultimate SP1, which was provided by the school I work for. I use their software because I live in China, and haven't seen a legit copy of windows for sale during the year I've been here. I am also pretty certain the copy they gave me is legit: It looks legit, and windows says it's legit.
I've tried both 64 and 32 bit versions. Right now I have a clean install of 64bit windows SP1, with only drivers (newest, just downloaded), browsers(Chrome, IE, Firefox), VLC, and Winrar installed. I choose not to install Antivirus this time just to make sure it wasn't causing problems. I also haven't updated it out of fear that one one of the updates was causing the problem. I'll do a selective update now.
Please help figure out why my windows runs like crap.
If is it a hardware problem, then it means whatever component is broken, the other component of the same type has the exact same problem. I find it more likely that windows has a problem, rather that two components with identical problems.
Has windows just gone to crap? Do I need to go back to Vista or XP? Is it time to make the jump to linux? Maybe I should just port android over to my pc because my freaking phone performs better than my computer.
CPU: E4300, Q6600
