- May 9, 2019
Hey guys I am wondering what do you guys use windows or linux and why? I look forward to hearing from you thanks Gabe.
Thanks for your help, what operating system do you use for linux? Could you also provide a pic of what your setup looks like? I look forward to hearing from you thanks Gabe.All my computer usage is done with Linux/Unix operating systems. Open Source has ample tools for office, photo editing and music & video, and I don't use any proprietary 'Windows only' software so no need for Windows at all.
The main machines I use are listed in my sig, including the OS each runs. The server rig- a Supermicro with 2 Xeon E5-2670s is featured & pictured in this thread:
https://www.overclockers.com/forums/showthread.php/783481-Server-as-workstation
The Asrock rig is in a black Chieftec case, as is the GA-78LMT-S2 + Phenom II X4 965 machine, except in a beige Chieftec.
The Dell Inspiron laptop currently runs Ubuntu 18.04, but has had Antergos, Fedora 28 and Debian previously.
hey D wolf, Thanks for your help.The best advice I can give is to use what works best for you. If you want to learn/play/explore then by all means pick a Linux distro and start exploring. If you just want to be able to turn on the system and run your apps, then any OS will be fine.
I use Linux, though I do still have several Win 10 installs in the house. I also run Windows in a Virtual Machine for those apps that don't yet run on Linux (only one at this point, the update software for my Rand McNally GPS)
There are now Linux distibutions (Mint, MX Linux, Solus, etc) that install and run just fine out-of-the-box. No real need to learn anything new, it all just works, like Windows does (for what that's worth). And the communities have grown incredibly in the last 10 years. You will find answers to problems you encounter as easily for Linux as you can for Windows, sometimes even more easily.
So as I said, use what works for you and don't let anyone tell you what you 'should' or 'must' be using.
Good Luck!
~DWolf
Windows. It's that simple especially if you are a gamer.
Such an open ended question!
Windows.
Unless you know Linux well or have the time, patience, and inclination to learn it, I would stick with Windows. While most of what can be done in Windows can be done in Linux, it takes a bit more effort, and there is a learning curve. All games do not work in Linux IIRC... so if you game, that isn't the OS to be on.
Linux has its advantages, in particular for an intermediate to advanced user. But I rest my head on Windows.
My suggestion....... Go Windows and maybe load up a separate HDD/SSD with Linux or run it in a VM and play. When you feel good enough about it, switch over.
