- Aug 29, 2012
- Colorado
SPECS:
CASE:Cooler Master CM Storm Enforcer
http://www.geeks.com/details.asp?InvtId=SGC-1000-KWN1-R
PSU:Logisys 480W 20+4-pin ATX Power Supply
http://www.geeks.com/details.asp?InvtId=PS480D-BLK
MOTHERBOARD:GIGABYTE GA-970A-D3 AM3+ AMD 970
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128521
CPU:AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
VIDEO CARD:SAPPHIRE Radeon HD 6450 1GB 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102933
MEMORY:Pareema 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820576011
HDD: 500GB 7200RPM SATA (Old Laptop HDD)
Note: Taken from an HP dv7-2270us laptop
I recently built this computer. I used my old hard drive from my HP dv7 laptop that was loaded with Windows Pro. When I started up the computer I was never asked to install the operating system. Infact when it loaded it loaded as if I was still on my laptop. The windows lock screen came up and showed my name. I entered my password and up popped my desktop. It had the background, all the icons, and I even tried some of the programs and they worked. I am not sure if this means that I already have windows pro or not and am woundering if someone can explain this to me. I have already purchased Windows 7 Pro SP1 to load but have not used it yet.
Can somebody tell me if I still need to load the new windows from the disk?
Am I ok to just keep going as I am?
If I keep using it like this will I still be able to get updates and use all normal functions of Windows Pro?
Is there anything I can do to check to make sure I have full functionality of Windows Pro?
Thank you all for your help.
