- Dec 30, 2003
Hello!
I would like to ask whether there is something like GNDS on Athlons. My problem is I can no longer run the frequencies / voltages I ran when my Mobile Athlon XP-M 2600+ IQYHA0352MPMW was new (two months ago). I have quite inadequate cooling for it - Arctic Cooling Copper Silent 2 TC (I have it because it is quiet and doesn't cost too much). My mobo is EPoX EP-8KRA2I, have Enermax 353W ATX12V v1.1 PSU and quality RAMs. This mobo has 3-phase voltage regulation with 6 MOSFETs each 45A max. There are 5 capacitors near socket and other bigger behind MOSFETs. In my opinion the mobo has quite good voltage regulation and I never suffered any problems with stability. The only drawback is there isn't 12V Power connector.
I used to run 2400 MHz / 1.65V what was stable (at 1.625V Prime failed after more than five hours). Now I need 1.675V as with 1.65V Prime sometimes fails after random number of hours - can be half an hour or more that four. The same is for lower frequencies - 2300 MHz at 1.575V (was 1.55V) and 2200 MHz at 1.475V (was 1.45V). Although weather was hot in Europe in last weeks, my temps doesn't seem to increase and I have around 65 with Prime. Yes, it is quite hot but it was rock stable and now has sometimes problems. I noticed that maybe running higher RPMs on Enermax rear fan improves stability (?) of CPU at all frequencies. What I noticed when CPU was new was it runs so hot. At 2400 MHz / 1.65V it run as hot as my older Thoroughbred 1700+ B0 DUT3C at 2200 MHz / 1.825V. With Tbred, I could run 2000 MHz / 1.6V with idle temp of 35C and 1000 RPM on CPU cooler. With this mobile, I have in idle 40C at 1400 RPM. Can it be this CPU suffers from excessive leakage and therefore doesn't like voltages that are no problem for regular desktop parts? I noticed here IQYHA should be best overclockers but also run much hotter than other series.
Another thing on this topic... my friend with the same CPU batch (IQYHA0352MPMW, XP-M 2600+) ran 2600 MHz at 1.8V prime stable all the day with his watercooling. He had temperature of around 50C. Now prime fails within few minutes and temperatures seem to have increased to 53C. He tried new PSU - no improvement. He tried cooling MOSFETs - no improvement. His mobo is Abit NF7 v2.
Any suggestions what is happening?
