Okay, so I put an xp1700(palomino, cpustepping:A5) in an old kg7-r mobo. So I've already been having problems, and I don't know what's causing it, but it kinda freezes at random times for a few seconds, and whenever I open a movie, it skips like 4 times, then plays. So anyway, now that I put this cpu in, and whenever I try to play a game, it locks up. I was trying to overclock it a little bit, but it never got hot enough to damage it. However, when I was testing the FSB, I was just going into the bios, setting it, then saving and exiting. If it booted, I'd go back to bios, raise it one, wait a few seconds, then do it again. Could this have messed it up?
I should mention that I cleaned the heasink/cpu off with rubbing alchohol, as I think that was safe. I tried putting it on, but couldn't get it on. So I took it off, took the thermal paste off of it and the heatsink with rubbing alchohol, but it was giving me some trouble, so I used nail polish remover on the heatsink. I'm wondering, could nail polish remover had screwed something up if I put the heatsink back on too early and it got on the cpu? I wiped it off again with rubbing after I was done I think, but then I put the paste on after I wiped it off with a napkin I think, and put it back on, and got it on this time.
!!!!Another thing, I guess this thing was penciled in to unlock the overclock..now if I accidently smudged or wiped off some of that, could that cause something like this to happen? because that is very possible and probably the most likely thing that might be messing stuff up. It seemed like no matter what I did when I was trying to OC it, it wouldn't go past 1640mhz either, and also, when I'd do like say 12x140, it wouldn't say 1680, it'd say lower..or it seemed like it'd always say a lower number of mhz than the multiplier x the FSB.
So when I was trying to check the fsb, i should mention, it booted up, I ran a memory test in everest, and then like the icons and stuff on my desktop were chinese and had squares and stuff, and like half of my icons were missing.
That's about everything I can think of, but it seems like it crashes when I'm in games or trying to load one (hl2) for some reason.. I ran a game(starcraft) and let it sit idle in a chat room (it uses 100% cpu in battle.net) and it didn't seem to restart, i left it open for like 5 minutes before I started doing the OC **** mentioned above..and it didn't restart. But it seems to be running okay when I'm -not- playing games.. and it's at 32c, so it's not hot.. thanks for reading all this.
Adding this one thing, sometimes it sounds like the cpu is making some noise, like a clicking maybe.. almost like a hard drive, but my hard drives don't make that noise..I dunno what it is.
-Weird, and now a few minutes after posting this, all of my internet cache and cookies are gone. Maybe my hard drives are wigging out.
Okay, apparently my comp freezes when I open my virus scanner as well. I'm starting to think that the restarts are caused by some kind of malfunction in one of the instruction sets or something. Like, the programs that are using one of those special instructions, so it runs faster or whatever, is messing up and freezing my computer. IE must not use any of those, because it is working fine, if my theory is correct
Hmm..now my internet cache and cookies are back. I'm thinking it's my hard drives now, hmm........ I hate my computer.
When it freezes, it makes a lot of static noise too..not sure what that is about.
okay, it also does freeze if I just surf the web, after about 20 minutes or so
