- Sep 17, 2001
- Nothingness is Everything.
Okay Home Depot was out of 1/2" id T-Fittings, so I decided to try and use a Y fitting that I had around instead.
This is for my bleed line obviously, and I was just making sure that it won't cause the water to divide evenly, and spray evenly out of the 'y' to both tubes hooked to it.
I assumed that because it would go :
Pump-> WYE -> -1 bleed tube to the top of case - 1 tube to rad at top of case->GPU->pump
Will the pull of the pumps inlet cause the water to be mostly drawn into the cooling loop and not "out of it" by means of the t-line?
(for some reason that was hard to explain )
